Just joined this morning. Daughter has 2000 Accent which stopped running last night. Joined to see if anyone else had the same problem, and more importantly the fix!
Well right up after a quick search of the forum I found a thread discussing a similar problem with a 2002 Accent. Read through and saw a heap of possible causes, all of which made me quite concerned how much this was going to cost to fix, let alone narrow down to the actual cause.
Took away some ideas and after a bit of time found what the fault was with daughters car. It's now back on the road and running fine :D
I've posted my fault finding and solution on the thread. Hope it helps someone else along the way.
