I recently changed the head gasket on the accent. Because it blow
I take off the cylinder head.
But first I take off the rocker arm assembly first with the bolts.
- I put on the head gasket and cylinder head together. I torque it to the correct specs. I put on the rocker arm assembly and I torqued it to the correct specs but when I check the first rocker arm it wasn't on the valve.
- How to align the rocker arms to the valves?
