hey guys just got my firsst car ... '97 hyundai accent i 1.3 manual
wanting some cheap mods to do on it to 1 make interior look better and 2 to make the car have a little more oomph :)
ive just cut down gearstick so now gear stick is about 4 inches long which does improve shifting quite a bit
any other idea's?
getting a rev counter (2").. volt metre oil pressure and water temp (all 52cm) gauges making custom pods the oil + volt + water gauges are going down the right hand side window screen brace (if you get what i mean dont kno how to explain it)
and the rev counter on the left of dash just above the centre vents and to the right a bit
different gear knob and handbrake handle on the way as well as new white gaitors for both
going to get a piper cross induction system, bosch HT leads, and Bosch superfour Spark plugs..
hopefully Red anodised hosing and battery covers and stuff
also going to re cover seats with leather as well as parcel shelf
new momo steering wheel + NRG quick release hub and boss on the way <--- dearest part of whole car lol
stereo just put in
with 2 6x9's .. looking for a sub
the rear side bits ... with the arms rests are hopefully getting sprayed black
and the front door cards getting re covered .. leather
anyone else got any other ideas? :whistling: :innocent:
also what wheels can i put on without rolling my arches (alloys) also what stud pattern is it?
cheers everyone
kelv
(p.s will put pictures up when allll this is done)
(p.p.s where can i get body kit xD)
I think 4x114.3, however: there is apparently some screw on the back brakes which may interfere with some rims...
Sounds like an awesome plan you've got! Please post pics when its done!
If you really want more oomph, you should strongly consider swapping in a 2.0L Hyundai engine from around the same age. Its a relatively simple swap.
QUOTE (atrain @ Jun 14 2010, 07:37 PM) index.php?act=findpost&pid=332936
Can i not just unscrew the screw?? ...
Also what size inlet would i need for a muffler
