1 - 9 of 9 Posts
I bought my 2006 Hyundai accent from my buddy,and a deer hit the front driver side fender.So i went to repair the fender and side repeater and i can't seem to find the wire harness to hook it back up
so i decided to remove the other one and follow the wire and the wire was cut,
I need this fixed to pass my inspection,i guess i will have to pay for new wiring...sigh
considering the location, a crimp connection would likely rot out after a while. a more permanent fix is solder and seal it. shrink wrap with the glue in it if you can fit it on there.
He's in Maryland, so it only gets inspected once, never inspected again. Just go up to Crazy Rays in Jessup and get yourself a pigtail and crimp it on there.
Super Moderator
Or replace both repeaters with the body color side moldings that most of the MC Accent 4-doors had. ;)
My 2006 4-door had the moldings there, and I think only 2007 or so had the lights on the 4-door. If yours is a 2006 with them, you've got a unique one. :) All 3-door MC's had the lights.
Ugh.
How did it get cut? From removing the old Fender?
Agree with Zero. Make the fix a bit more permanent if possible. Tho I think you could get away with a crimp & heat shrink as well. I know Radio Shack has Heat shrink tubing, but look around.
Personally, I'd probably go with Posi-Locks weathertite connectors on the off chance I ever had to repair it again. They're easy enough to undo that way:
Posi-Tite- Watertite Connector
1 - 9 of 9 Posts
