Hello everyone,
i need to replace the key ignition on my hyundai santa fe 2003, 2.0 crdi. I already have the whole piece, i only need to get off the old piece. I´m trying, but i can´t, because there not enough place on the right side, to take the whole piece out. Any suggestion? Thank you very much!
Is that a loose ignition barrel hanging off an octopus strap? Is that open hole in th eright of the picture of the opening the barrel was?
That pin looks like it will depress once the rest is removed. I know for the key barrell in one of my Hyundais, the key needs to be at ACC position, then there's a pin that is depressed and it pops right out, maybe it's similar for the rest
yes, the ignition barrel hanging is the new one, so i can start the auto. That open hole in the right of the picute ist the old ignition barrel, that i need to take out.
I don't have my manuals with me but I think if the column is dropped, thre may be a small hole to depress that pin and remove that body but I can't say from experience
Discussion Starter #7
Thanks Gerard, i´ve already pushed the pin, the barrel it´s already out, the only problem ist that´s there not enough space to take the whole barrel out.
