Hi, I tried to replace the reverse lights to LED Projectors. When I tested it, it worked. Then when I reversed to park car back into garage it stopped working and I was like... then I changed bulbs back to OEM and it didn't work.
What should I do?
Fuse?
If Fuse, Where and Which?
Discussion Starter · #2 ·
Anyone?
The fuse is in the engine compartment. Remove the cover off the ER/Fuse & Relay Box. It is a 10A fuse.
It could be that the bulbs you use draw more than 10A. You could install a larger fuse, but the wires may get too hot and burn up if the amperage is too high. Since the reverse lights do not stay on very long for the most part. It may work without a problem.
There are charts you can look up to see what the recommended amperage rating is for a certain gauge wire. Then use what you feel safe with.
