Thanks to you I removed the starter with ease. Removing the exhaust manifold was easier then I thought.Remove ground from battery. Starter can not be effectively tested until you get to it, so you really have to follow these steps for testing or for replacing.
1) Remove air intake. 3 plastic screws and lift upon the inserts.
2) Remove the radiator fan. Two screws in the top two corners, two clips on lower corners. (there is a plastic cover on the top left corner that can be removed with two screws, I did this but don't think it was necessary) The fan is tight to get out, but it can be done, just don't break anything.
3) Remove metal heat shield on top of exhaust manifold. 4 bolts. Unplug o2 sensor from clip. Use needle nose pliers to release plastic wire tie.
4) Remove top exhaust manifold. 8 nuts/threaded rod. 14mm
5) From underneath the car separate exhaust manifold from first section of exhaust pipe. 2 bolts 17mm. (I had already removed the drivers-side engine mud guard. I don't know if this is required, but if you need to remove it, it has 5 bolts and a plastic screw/clip)
6) Remove exhaust manifold.
7) The starter is not easy to identify because it has a shield protecting the wires. It is bolted to the engine using 2 long bolts that are threaded on the end. Both bolts are accessible on the transmission side / drivers side. The top one is obvious, but the second one you might have to search around with your fingers, but it is beneath the first one.
8) Remove single bolt holding main power wire and unplug the clip.
Reinstall in reverse order. Make sure you remount all the wires correctly to avoid future damage to wires.
I had to jacked up the car to remove the 2 exhaust bolts at the bottom of the exhaust manifold.
I'm waiting now for my new starter to arrive, I hope reinstalling will be as easy.
Is there a simple way to test a starter at home?
Thanks
