I got a cd stuck inside my infinity stereo. It plays fine but wen i press eject it doesnt come out. Wen i switch off and on again it plays normally.
is there any way to takee the cd out without opening the stereo from the dashboard?
Not sure the model of the stereo but most cd players have a manual disc eject. It should be a small hole behind the faceplate. You can push it with a pin or paper clip. That will get the cd out.
Sometimes you can disconnect the negative battery lead for 5 minutes then reconnect it and the cd can be ejected. Sometimes.
I had the same problem with my 6-disc head unit. I used a small plastic knife and incerted it on the right side (maybe it was the far left; it was so long ago) very quickly. It activated the motor inside and the CD ejected. Do this at your own risk. It took about 3 tries. Don't push the knife all the way in the first time. Go in a little bit at a time.
I have since replaced that head unit with a Pioneer AVH-3200. Who uses CD's anymore when you can use a 8GB or 16gb USB or SD card.
