Hi
I have a Hyundai Santa Fe 2008 2.2 diesel
I have a problem which I cannot fix with my indicator. On one side only the indicator is flashing at double speed (like a bulb has blown). The problem started after blowing a maxi fuse? I have taken it to the garage but they cannot figure it out!!
I have tried the following:
  • Changed all bulbs
  • Checked all other bulbs
  • Changed front indicator bulb holder from on side to the other
  • Plugged in the other side rear light
  • replaced the ICM relay
  • adding an extra bulb!! (Knew this wouldn't work but thought maybe increasing the resistance may work)
None of these made any difference. I am not great with electronics so if anyone has any suggestions what it could be or that I could test i would be grateful.
Thanks
Discussion Starter #2
UDPDATE: after fiddling around today I have found a solution (sort of) I thought I would post it here just in case anyone else had this issue.
The problem is caused by the trailer hitch, there is some sort of problem with it, I have now disconnected this wiring loop and everything now works fine.
