QUOTE (Sequoiasoon @ Jan 22 2011, 02:24 AM)
index.php?act=findpost&pid=393228
SBR -
How much are the cables? What is the warranty time frame (5-60 or 10/100?). How hard to change for a very good DIY person?
This info is for V6 3.3 Sonata and 3.8 Azera---
Last price I had on the cable is approx $139... dealer should idealy have 1 on the shelf... New part number ends in 3K111 I think it is.. If dealer fella any good, he should be able to grab it right off shelf or know exactly what you asking for
Warranty on the cable is 5/60...
DIY.. not hard at all.. worse part is you will need to get under front to swap cable end at starter (part of the replacement part).. end at alternator post, some routing across front of engine, end at fuse box, and battery cable clamp.. at worse maybe 1.5hr at home if you not in hurry.. maybe an hour or less if you determined to be done with it.
All done from top right there, except for the starter post and soleniod connector. Straight forward job, couple wrench and socket is all.
Appears you have a 2.4, that cable not been a problem for us... I would suggest anyway that you follow the negative cable to the place where it end,,, likely bolted to painted panel (insulation) and the 2 bolts ?? have rusty threads (more insulation)... If the cable end bolts to painted fender, remove cable, and grind the paint off so the lug mates to clean bare metal.. smear the bare metal with anti-seize or other to prevent rust.
While you got the battery loose, there is a strap on left frame rail by battery tray, goes to trans case... grind paint off frame rail mounting point too.. see how that works out.
