1 - 9 of 9 Posts
I have a 2011 i10, 16000 miles, and Thursday it would not start, so I called breakdown and after a lot of 'go's' he got it started, he said it could be the stater motor or the relay,
worried this might happen again, I went to my local garage and told them, and they said they could not say what the trouble was until it did it again and when it did I was to get it straight to them, not get it started.
Now that for me, being on my own, also I go out sometimes at night, is not good advice.so not keen on that,
Was thinking of going to the Hyundai garage on Monday,
Since this happened I have used it 10 times.
So was it just a unlucky blip, or am I heading for trouble???
You could be right, have just read the paper-work I have and it says,
"Your car has a balance of 5years unlimited mileage warranty, effective from date of registration".
am off down Dealers on Monday,
Hope you are right, thanks again.
OK. See if this will help:--
Unlike the OBD-I connector, which was sometimes found under the hood of the vehicle, the OBD-II connector is required to be within 2 feet (0.61 m) of the steering wheel (unless an exemption is applied for by the manufacturer, in which case it is still somewhere within reach of the driver).
Discussion Starter · #8 ·
So are you saying that if I was to find this OBD that could be the problem???
Discussion Starter · #9 ·
Took car to Dealer this morning, they are going to put a new started motor in tomorrow, left it there and have a courtesy car, a nice i2,
was very pleased with the way I was treated,
1 - 9 of 9 Posts
