Hey guys/gals.
Just popped in to say hi.
I'v been on the fence with buying this 06 sonata I found.
Has 160k. Cosmetically good. Only thing I can see with a brief overview is it pulls slightly to the right and the alternator looked to be covered with oil or grease.
Asking price is $5000.
Any thoughts would be appreciated.
Thanks
Hey guys/gals.
Thanks
:00000732:
Wow, thats a good price.
The oil leak is "normal" as it happens to a lot of owners. Can be fixed by installing a new valve cover gasket and using the updated grey silicone to seal it... there is a thread somewhere here talking about it.
Pulling could mean it needs an alignment. Mine pulls very slightly to the left. There are quite a few complaints about the slightly off center issue. So it could be "normal". On certain roads its more noticeable.
A few other things. If you do get it, I'd change the transmission fluid to something aftermarket (Castrol Transmax Import Multi-vehicle) and the spark plugs too.
FYI: This probably would have gotten more traction in the NF area.
:00000732:
Thanks I thought about the post in the NF section but I wanted to say hi too. :) I will do a copy paste.
Thanks again.
