Hi, I own a Hyundai Elantra, 2003 2.0 TDI. The heater has recently stopped blowing out anything. The temperature dial works i.e goes from hot to cold, A/C button works, rear heater button works, so it would seem the heater control panel is fine in itself.
Any ideas.
Thanks
I did check both fuse boxes but have found no faults. Are you thinking this is may be the mostly likely cause of the problem?
I would troubleshoot this by back tracking power from the switch to the fuse box. If there's power at the fuse & the switch it's possible the switch itself is at fault.
