I have tried to get online a 2011 heat core for my santa fe 2011. I have not yet found it. I don't want to go to a dealer and you know why.
I found a core for a 2007-2009 santa fe and when I read the specs, it looks like this heat core will fit inside the slot where it normally goes.
Could anyone tell me if I am right or wrong? thanks
You are trying to fix your car with parts that will not fit it. WRONG..
Well friends, just for your info.. I took a chance and bought a heat core from a 2007 santa fe. The measurements from this santa fe were exactly the same as the core from a 2011. The 2 tubes coming out to the core are also shaped as a 2011. The tubes lengths are the same but the only difference is that the tubes diameter are a little bit smaller. I installed it and will try it this winter.........I will let you guys know about performance....
Thanks for your help
