Hi, I 've a problem with heater core in my girlfriend Getz (wet floor on the driver's side). Do you have manual of replecement heater core in getz ??
Greets from POL
Konrad
2007 Honda CRV
Is that stuff making the driver's side floor wet ... coolant or water??
If it is water then Grcauto is right
If it is coolant then you are right
it is coolant (glycol is greasy)
Avisitor, do you have any manuals for getz for replacement heater ??
2007 Honda CRV
Sorry, no manual.
And from what I know about changing heater cores, it can take quite a bit of time.
The part may not be too expensive but the labor is the what hurts.
On my Elantra, it was easy enough by cutting the metal connecting tubes
To get the heater core out
And putting the new core on with hoses with clamps to bridge the cuts
I can't find anything to help with the Getz
