My heater and air con have both stopped working. The fans still blow and the ac pump kicks in just neither work. I have changed the display unit but fault remains. Please help.
Can you be a bit more specific? Stopped working in what way?
The blower fan is working but you can't control the temperature of the air that comes out the vents, or what?
Sounds like maybe the blend door/temperature actuator is faulty. I think it's on the heater box behind the center of the dash, on the driver's side...assuming you have a LHD car.
It should look something like this....but there are usually 3 or 4 actuators on the heater box so you need to make sure your looking at the right one.
Turn the controller to full cold. Pull the fuse for the HVAC wait 1 minute and replace. Turn the Key on Engine off....DO NOT touch any control until the system goes through it's learning process about 1 minute. Now start the vehicle. Does it work now?
