· Registered
The door arm rest/door pull has a black plastic button that covers a Phillips head screw, that allows for door pull
arm rest removal...while vacuuming out the CEO's Tuck the other day, the vacuum sucked out a couple of those
"buttons". I found one in the bag, so far; the other is MIA.
I suspect the car wash vacuum people will be even less careful, and most car wash joints have an even higher suction
rate vacuum than what I was using.
Not a big deal, but live and learn.
GL, mD
· Registered
QUOTE (motordavid @ Jul 8 2010, 10:11 AM) index.php?act=findpost&pid=339794
GL, mD
I did this to mine last month... I noticed it right after I did it on the front pass door... so I was able to find it and dig it out of the wet/dry vac disposable bag....
· Registered
QUOTE (kendawg @ Sep 24 2010, 05:38 PM) index.php?act=findpost&pid=358530
I did this to mine last month... I noticed it right after I did it on the front pass door... so I was able to find it and dig it out of the wet/dry vac....
Happy to report that I dug through the shop vac disposable bag, for the third time, sifting it slowly, and found the 2nd plug!
What a PIA :whistling: ...but, theCEO is very happy. I'm thinking of spot gluing the lil' buggers in their place...maybe silicone them or,
some low impact plastic glue. For those of you that use a thorough car wash, the vacuum people will suck them out,
I suspect.
GL, mD
