1 - 8 of 8 Posts
Good morning,
I have the Elantra with running lights.. Thinking about 6000k. I would like to match them with the head lights. I know lows are hb3 and high h7. Is there an easy plug and play bulb out there to do the job cheaply? Thanks.
Here is my config.
Low beam with plug-n-play load resistor to remove dash warning
Code:
https://www.amazon.com/gp/product/B00VNBDOV2/
https://www.amazon.com/gp/product/B01N3B0NLE/
DRL+high beam (no need for load resistor, no dash warning)
Code:
https://www.amazon.com/Auxbeam-Headlights-Headlight-Conversion-Bridgelux/dp/B01KFBPAJO/
My first preference was this
Code:
https://www.amazon.com/OPT7-Fluxbeam-Headlight-Bulbs-Arc-Beam/dp/B06XXRSFZS/
Both of them work as both DRL and high beam, although one is half the price.
Turn signal bulbs: 1157 white (will need resistor, there will be hyperflashing and dash warning)
Code:
https://www.amazon.com/gp/product/B01N8T46X1/
See my post here
Code:
https://www.hyundai-forums.com/ad-2017-elantra/521569-turn-signal-led-3.html#post5813369
Disclaimer: I am not the seller of any of the products. I just bought them after extensive research and putting them here for future amateurs like me.
Turn signal/parking lights:
Low beam+parking lights (automatic):
DRL:
@piby2, you might want to alter that last photo--kind of defeats the purpose of altering all of the other ones... :)
2017 Sonata Sport 2.0T
t least 3 of us over inthe Sonata LF forum have used these.
They match the DRL and are plug and play, no error codes and on the Sonata they fit into the housing easily with the dust caps on
[ame]https://www.amazon.com/BEAMTECH-Headlight-8000Lumens-Extremely-Conversion/dp/B06XHD4HV3[/ame]
I'm running;
Morimoto Eltite 35w 5500k (9005) hid kit with can-bus harness.
This matches the led running lights perfectly.
White car is mine but both both are running same kit. Blue car is running 50w @ 6500k
Don't the Elantra's take 9006 low beam bulb? All these links you guys are posting are for 9005. Just curious.
Sent from my SM-G935W8 using Tapatalk
1 - 8 of 8 Posts
