My 2007 accent headlights not working high or low beams , on flashing the high beams work if I hold the handle , drl only and is weak .
Can't locate drl module ( possibly the issue here ) no relay related to headlights been found ( in engine compartment) just the fuse for lh and rh lamp and they're good ( inside fuse box ) , behind the fuse box there's a few relay but no marking as what they are for .
Not sure it is related but it started after I did some work on my clutch and I made sure ( rechecked 3 times ) that all connection were back in place .
Anyone can help me here ? As for troubleshooting or locating the relays or drl module?
Probably the switch. It's full current through the switch for the headlights..
The switch grounds the circuit. But it is full load.
Thanks , I tested my switch , it has power on when switching off lights and grounds it when turned on , so it seems to be working just fine , I have to do more testing , this problem has me puzzled a little ( I'm usually good at figuring electrical problems ) just that over the years the circuitry has become more complex
