Daughter left her headlights on and killed tge battery and also blew a 100amp fuse under the bonnet, l have replaced the battery and the fuse as well as both headlight globes, tail lights, brake lights and park lights work fine but still the headlights dont work and neither does the aircon or the aircon fan, l have checked all the fuses but still no luck, any ideas please
The 100A fuse blew either because someone jump started the engine and connected the jump leads the wrong way round, or the battery was connected the wrong way round. In either case it isn't unusual for other fuses to blow too, so I'd suggest rechecking ALL the fuses with a voltmeter or test light rather than pulling each one out and looking. And it would be best to have the engine running with the headlamps and aircon on while testing to make sure all the circuits are powered up.
