2003 Tiburon GT. Needs help. Here's what I know so far:
Currently has a leaky drivers door seal which I need to replace, and also figure out what is causing the headlights to only turn on in high, and the windows to not open. No blown fuses that I can see, thinking its something involved with moisture having gotten into the car.
I messed with it some more today, and now the passenger side opens, after some protesting on the car's behalf. So I dont think its in the switch, as that is plugged into the same set of wires on the harness. So apparently it must be the window regulator. Is this a known problem on this generation?
Also, why in the world would the headlight switch be tied into this? All I can figure is that the moisture in the air (car sat a while) must have corroded the contacts. But why just those contacts? This is stupid. Anyone had the same issue with theirs?
One last thing. Where can I get a good door seal kit for this?
