Hi guys, so I just changed my headlights to LED. Has anyone done this and had trouble? When I try to put the headlights in, it almost seems like it wants me to twist them in, but the metal piece is in the way. This makes the lights not sit flush in the spot.
Thanks for any help.
There are a large variety of LED lights. Which ones are you installing/having trouble with? Most I have seen have a ring that you put in the socket and secure with the metal clip. Then you just push in the LED "bulb" into the ring. If you must twist it, you might run out of room and the heatsink will catch on the metal clip not allowing you to turn. This may take some more effort to work with. I have seen in other places, those who have cut off some of the heatsink to make more room for the clip. Do you have any pictures of the bulbs outside the headlight and maybe where you are getting stuck?
