I'm trying to adjust my headlights, and the adjustment screw is spinning free. I took the cover off the back (like I was going to replace a bulb), and the frame or whatever the inside assembly is called, moves easily by hand. It pivots, like I assume it is supposed to, but the adjustment screw seems to be disconnected from it, so it won't hold position and I can't adjust it. I confirmed on the other side that this is not how it is supposed to be. I tried holding it up by hand while turning the screw, but to no avail. Is there a trick to getting the screw threaded back into whatever it threads into in that frame? Is it possible to remove the rear housing so that I have access to that spot and can get them mated? Is it probably stripped and I have to just replace .... replace what?
By the way, 2009 Limited Santa Fe. I can't remember if it is the "early" or the "late" model, but it uses the H7 bulbs for low beams, not the H11b bulbs. No idea if that makes a difference.
Thanks in advance.
Thanks in advance.
