1 - 9 of 9 Posts
good luck getting one any time soon.. personally I dont think it will happen for a couple of years if ever as the Elantra is not a "tuner" car, at least from a reputable company.
How about you gut the cat, it will have a very similar effect. I am assuming we have the typical primary cat the the manifold and a secondary one futher down stream. If that is the case, gut them both as you wont pass a sniffer test with just one of them and the ECU tricks are not the most reliable from what I have found in the past.
Headers ... on our car ..... really??? What do yo hope to gain besides working to void you warranty? If you want power and speed then you should have bought a car that would give you that. Not being a dick - just askin' ?????
Let me correct you... HEADER! not a V so there's only one. Lol and Boardman it depends on your dealer. As long as I do what my Service Manager says to do, I won't have warranty issues ;)
As long as you have the non-California emissions regulated manifold, there is really nothing to be gained.
Looking at the stock 4-1 design, unless you do other supportive mods (cams, p&p, intake etc.) there is no point.
Are the car companies really still making 2 different exhaust systems, one for CA emissions (and states which had adopted the CA standard) and the rest of the USA?
I have no clue since Calif. dealers have a mix of PZEV (models xxxxxF4P) and non (xxxxxF45). Mine is D1503F45 - GT manual trans non-PZEV.
Discussion Starter · #8 ·
Well
If you really want to make your car "fast" then theoretically you should put the best brakes you can without over coming the brake torque of your car's power-to-weight ratio. Second to that is to lower the differential gearing, but since this car already has 4.33 ring and pinon setup, unless you plan on going drag racing I don't think that's an option for this car.
Unless you fiddle with transmission gearing and THAT is beyond me, and my wallet!!!
Just saying
1.8 Elantra engine already come equipped with a shrt tube header..pre and post cat ox sensors for fuel trim and cat monitoring..
1 - 9 of 9 Posts
