Hi
I recently had a new clutch installed in my 2000 accent gl but over the last 24 hrs it seems to be hard to get the car into gear, its not making any grinding sounds but when trying to gear up and down and down i find myself having to shove the car into gear :(
any suggestions/ideas as to whats going on?
it does sound that the clutch hydrolics are a likely suspect, it might well be that the system needs bleeding. however since you have just had a new clutch fitted l would suggest you take it back to where you had it done, they should sort this out for you free of charge
