2001 sonata 4 cly automatic, since I had the sub frame recall installed ,at least 5 months ago I have had squeaker under the frame , so what I need to know is what does it entail to perform this recall or whats removed to do it and can i spray silicon on the areas that seem yo be squeaking? thank to any one who can help
What does your receipt/invoice state was done, and what parts were used ..
DO not read it and try to generalize in your own words,, post exactly what is says.. post parts used from the parts list.
Seeing you in NY, and a 2001, I would venture without doubt that the subframe was replaced.
a sub frame recall 2001 hyunda sonata
I misplaced the paper work for the recall, how ever I remember it just said replaced sub frame assembly and performed a wheel alignment, ever since I hear a squeak from the sway bar area.
