1 - 1 of 1 Posts
ive sprouted a leak, check engine light came on and temp began to increase, i quickly turned my engine off and left vehicle.
its appears to be coming from a part of the engine bay i cant see.i suspect a pipe, as i filled the rad with water it quickly started to leak coolant from the a point roughly 1.5-2ft along from the coolant hose that connects to the bottom of the rad and travels along to the engine.im fairly sure its not the water pump which was replaced 6 months ago, and it probably wouldnt leak anyway to such a great extent..
i could really do with a diagram to help myself nd my mechanic when he has time to look at it. its not the rad either as i can see (jus not clearly enough to identify specific part) where the leaking water is coming from.
1 - 1 of 1 Posts
