· Registered
Hi all,
Bought a 2010 iLoad (H1 commercial van) 2.4ltr petrol and use it for recreational purposes, ie carrying a couple of dirtbikes and camping gear. It is almost perfect for the task and I have been very impressed with it's performance and fuel consumption for what it is. The issue is that the standard suspension is rated to 1 tonne whereas I doubt I would ever get to a load over 500kgs and the result is a very harsh, pitchy ride. Given that I don't need the carrying capacity I would like to either get a softer set of rear springs or, if it's possible, swap in the rear 5 link setup from the iMax. Anyone ever looked at the possibility of doing so or even done any suspension mods?
Thanks,
Glenn
· Registered
The 2008 i-Load had a thinner main spring than the later models, I was carrying a tonne or so & it was on the bump rubbers, would have loved to have done a swap but the van has been traded. We also have an i-Max, the rear ends are nothing alike, I doubt a conversion to coil springs would be feasible.
Matt
