Hi, Please help how to remove the dashboard of H-100. I want to upgrade the stereo I searched google with no luck. Thank you.
Is it a standard, off the shelf radio? If so you should be able to pull that out without a dash removal. There are special tools that you slide down each side to release the old radio so you can pull it out. I pulled the dash on my 99 H1 Starex to replace the Hazard light switch. Big job but not impossible. While I was in there i fixed my radio wiring. The previous owner had an expensive Pioneer stereo installed by a blind blacksmith that only owned a hammer🤪...
