2002 SF 4cyl, 4WD.
Can someone tell me where the electrical ground locations are? I assume there has to be at least one under the dash???
Would love to clean them.
I did search but perhaps not everywhere.
Tks
Rob
Discussion Starter · #2 ·
I'll answer my own question. It is behind the plastic trim by your clutch pedal/door hinge. Thanks HMASERVICE.
I am chasing low voltage (11.5 V) at the headlights.
If I put a meter on the light terminal and ground it to the engine, I get full voltage (13.5 or whatever). If I measure at the H4 plug, only 11.5. So poor ground somewhere or pitted points in the multi switch....I think.
If someone has been down this path before, pls chime in. Otherwise I'll post what I find.
Issue...poor headlights.
Polished lenses....better (they were really bad)
Replaced headlight units...better still....but not perfect. 11.5 v at lights.
Next...clean ground
Replace multi switch
then...I dunno..
