I am hearing a grinding noise when I turn the wheel to the left.. and when I straighten it again the noise goes away.. no noise at all when turning the wheel to the right. what could it be? 2006 Hyundai Santa Fe / 205,000 km's
You've got enough age on the car it could be a CV joint. Then they start to go bad they make noise on turns.
Sure it's not an ice build in the wheel cavity?
yup from canada.. maybe ice build up.. mind you it was in for an oil change and was sitting in the shop for about 1 hour. and haven't had any snow since then and this was a week ago for the oil change,. I did put new winter tires on in Nov. 2013 but I dont see any rubbing in the wheel well..? now it where the cv joint how would I check to see if its bad?
