1 - 8 of 8 Posts
Hi.
Where else can oil get into water system if head gasget is OK.
The engine oil is in good clean condition and not losing any.
RAC didn't have a ckue.
You can get oil into the coolant WITHOUT getting coolant into the oil from a failed headgasket.
Automatic transmission's have lines running through the radiator bottom tank to cool the trans oil. Could be that there is a leak into the cooling system via those lines.
Just a thought.
As johnad said from the transmission cooling pipes in the radiator is a common place. Also a crack under the camshaft will also pump oil into the cooling system. There's quiet a few areas that can cause your problem and their all bad.
1 - 8 of 8 Posts
