POPULAR TOPICS:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/162068-roadside-assistance.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/148583-chatroom-mpg.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163846-accidents-damage-stories.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/155379-what-car-did-you-trade-your-santa-fe.html
http://www.hyundai-forums.com/260-d...a-fe-members-post-your-introduction-here.html
http://www.hyundai-forums.com/260-d...fter-15min-using-bluetooth-phone-pairing.html
http://www.hyundai-forums.com/dm-2013-santa-fe/163456-diy-engine-oil-change-glossary.html
http://www.hyundai-forums.com/260-d...ile-broken-cracked-windshield-windscreen.html
http://www.hyundai-forums.com/dm-20...s-edc-etc-what-do-you-keep-your-santa-fe.html
INFO:
http://www.hyundai-forums.com/260-d...yundai-santa-fe-fsm-field-service-manual.html
http://www.hyundai-forums.com/260-d...oom-front-window-wipers-sizes-styles-etc.html
http://www.hyundai-forums.com/260-d...-fluid-capacities-pocket-reference-guide.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163473-diy-maintenance-check-list.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/162047-tsb-service-bullitins-2013-santa-fe.html
http://www.hyundai-forums.com/dm-2013-santa-fe/161765-chatroom-cabin-air-filter.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/153552-2013-santa-fe-bulb-replacement-guide.html
http://www.hyundai-forums.com/260-d...pection-necessary-every-3700miles-6000km.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/175097-fsm-hyundai-fluids-chemicals.html
Engine Threads:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/245457-video-engine-air-filter-check-replace.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/222665-if-your-engine-went-bad-vote-here.html
http://www.hyundai-forums.com/260-d...atroom-engine-trouble-noise-problems-etc.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/198153-chatroom-2-0t-engine-issues.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/185577-engine-dead-22k-miles.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/202082-engine-break.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/196273-2-4-engine-vs-2-0t-engine.html
http://www.hyundai-forums.com/dm-2013-santa-fe/197569-chatroom-santa-fe-spark-plugs.html
Check Engine Light Codes: (common)
http://www.hyundai-forums.com/dm-2013-santa-fe/327505-check-engine-light-code-p2118-%3D-throttle-actuator-control-motor-current.html
http://www.hyundai-forums.com/dm-20...gine-light-code-p0303-=-cylinder-misfire.html
Transmission Threads:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/231449-transmission-issues-2013-sfs-2-4-a.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/166049-2-0t-transmission-performance.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/203930-transmission-clunk.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/154990-awd-fwd.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/231137-gear-lever-problems.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/222137-transmission-shift-cold.html
http://www.hyundai-forums.com/dm-2013-santa-fe/332593-chatroom-transfer-case-fluid-change.html
DIY INSTALLS & REPAIRS: (do it yourself):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164238-diy-engine-oil-change.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163135-diy-change-sf-dm-fogs-lights.html
http://www.hyundai-forums.com/dm-20...-fe-sport-parking-brake-shoe-replacement.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/158517-diy-cold-air-intake-bpv-bov.html
http://www.hyundai-forums.com/dm-2013-santa-fe/246065-diy-rear-differential-fluid-drain-video.html
DIY: HITCH INSTALLATION INSTRUCTIONS (pdf)
DIY: New Oil Pan Install (pdf)
http://www.hyundai-forums.com/187-cm-2007-2012-santa-fe/84167-how-do-i-adjust-headlights.html
http://www.hyundai-forums.com/260-d...-removing-upper-dash-trim-center-storage.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/166817-radar-detector-mirror-mounted.html
http://www.hyundai-forums.com/dm-2013-santa-fe/321505-diy-front-brake-pad-check-clean-video.html
http://www.hyundai-forums.com/dm-2013-santa-fe/325657-diy-removing-front-bumper-cover.html
http://www.hyundai-forums.com/dm-2013-santa-fe/326498-chatroom-firewall-access-holes.html
http://www.hyundai-forums.com/dm-20...ire-pressure-psi-have-you-checked-lately.html
http://www.hyundai-forums.com/dm-2013-santa-fe/177274-front-pillar-removal.html
http://www.hyundai-forums.com/dm-2013-santa-fe/308402-radio-removal.html
ENGINE MANAGEMENT (modules & apps):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/161484-obd-modules-torque-kiwi-apps.html
LIGHTING (mods, installs, etc):
Headlight Beam Adjustment / Aiming (pfd)
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164308-diy-hid-xenon-install.html
http://www.hyundai-forums.com/260-d...-chatroom-hid-xenon-headlight-conversion.html
http://www.hyundai-forums.com/260-d...troom-drl-daytime-driving-running-lights.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/155308-led-foglight-bulb.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/159686-hyper-yellow-fog-lights.html
http://www.hyundai-forums.com/260-d...ailights-reflectors-license-plate-lights.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/157204-interior-led-lighting.html
EXTERIOR MODS:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163195-chatroom-plasti-dip-vinyl.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/162756-de-badge.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164322-flying-eagle-badge-swap-mod.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164278-rear-reflective-mod.html
CLEANING, POLISHING, WASHING (tips, advice, diy's, etc):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/161996-cleaning-tip-bumper-honeycomb.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/152812-chatroom-exterior-compound-polish-wax.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/158510-leather-seat-care.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/154031-cleaning-dash-suggestions-please.html
http://www.hyundai-forums.com/dm-20...r-bumper-paint-protection-vinyl-3m-other.html
AUDIO UPGRADES / MODS:
http://www.hyundai-forums.com/dm-2013-santa-fe/308402-radio-removal.html http://www.hyundai-forums.com/260-dm-2013-santa-fe/156428-audio-upgrade.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/160066-dash-kit-mounting-kit.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/149208-internal-hard-drive-capacity.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164326-dashboard-tablet-mount.html
NAVIGATION (in-dash):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/159912-australia-mapcare-updates.html
http://www.hyundai-forums.com/260-d...oem-inetegrated-navigation-2013-santa-fe.html
Suspension:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/232249-suspension-stiff-when-its-cold.html
OFF ROAD (mud, snow, etc):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/154566-chatroom-off-road-mud-sand-woods-etc.html
http://www.hyundai-forums.com/dm-2013-santa-fe/157542-chatroom-winter-snow-driving.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/156899-magna-awd-system.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/155405-blizzard-2013-a.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/227553-awd-diagonal-spin-test.html
TOWING:
http://www.hyundai-forums.com/260-d...troom-towing-hitch-receiver-trailers-etc.html
RIM & TIRES (OEM, all-season, winter, off-road, summer, etc)
http://www.hyundai-forums.com/dm-2013-santa-fe/150465-chatroom-winter-snow-tires.html
http://www.hyundai-forums.com/dm-2013-santa-fe/161183-chatroom-all-season-tires-oem-non.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164305-tire-pressure-sensor-tpms.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164317-new-aftermarket-rims.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/174321-wheel-offset-2-4-awd-sport.html
ACCESSORIES:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/159594-side-window-deflectors-rain-guards.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163252-accessories-galore.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164311-trunk-organizer.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/164310-chrome-accent-trim.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/162582-tint-new-2013-santa.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/158369-front-rear-push-bull-cow-bar.html
http://www.hyundai-forums.com/260-dm-2013-santa-fe/150422-all-weather-rubber-floor-mats.html
http://www.hyundai-forums.com/260-d...oof-rail-crossbars-both-pano-metal-roofs.html
http://www.hyundai-forums.com/260-d...-2013-santa-fe-running-boards-side-steps.html
http://www.hyundai-forums.com/260-d...nta-fe-hyundai-genuine-accessories-chart.html
http://www.hyundai-forums.com/dm-2013-santa-fe/300978-chatroom-dash-cams-diy-install.html
BLUE LINK (issues, stories, complaints, recommendations, etc):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/163391-had-some-fun-bluelink-app.html
HYUNDAI CUSTOMER CARE RELATED (complaints, issues, resolutions, etc):
http://www.hyundai-forums.com/260-dm-2013-santa-fe/162729-poor-customer-service.html
http://www.hyundai-forums.com/260-d...ehensive-reimbursement-program-mpg-error.html
(outside link) https://www.hyundaiusa.com/contact-us.aspx
INFO:
Engine Threads:
EXTERIOR MODS:
Suspension:
TOWING:
ACCESSORIES:
