MODS - This is purely an update to the pinned/locked thread above. I have updated all of the links to work with the new forum software. If possible please take the information here and use it to replace the old information in the pinned thread and then you can delete this thread. Thanks!!
POPULAR TOPICS:
http://www.hyundai-forums.com/threads/roadside-assistance.162068/
http://www.hyundai-forums.com/threads/chatroom-mpg.148583/
http://www.hyundai-forums.com/threads/accidents-damage-stories.163846/
http://www.hyundai-forums.com/threads/what-car-did-you-trade-your-santa-fe.155379/
http://www.hyundai-forums.com/threads/attn-new-santa-fe-members-post-your-introduction-here.163664/
http://www.hyundai-forums.com/threads/cant-hear-caller-after-15min-using-bluetooth-phone-pairing.158986/
http://www.hyundai-forums.com/threads/diy-engine-oil-change-glossary.163456/
http://www.hyundai-forums.com/threads/chatroom-fragile-broken-cracked-windshield-windscreen.155144/
http://www.hyundai-forums.com/threads/emergency-supplies-bags-kits-edc-etc-what-do-you-keep-your-santa-fe.156760/
INFO:
http://www.hyundai-forums.com/threads/2013-hyundai-santa-fe-fsm-field-service-manual.246089/
http://www.hyundai-forums.com/threads/chatroom-front-window-wipers-sizes-styles-etc.148243/
http://www.hyundai-forums.com/threads/fluid-capacities-pocket-reference-guide.162801/
http://www.hyundai-forums.com/threads/diy-maintenance-check-list.163473/
http://www.hyundai-forums.com/threads/tsb-service-bullitins-2013-santa-fe.162047/
http://www.hyundai-forums.com/threads/chatroom-cabin-air-filter.161765/
http://www.hyundai-forums.com/threads/2013-santa-fe-bulb-replacement-guide.153552/
http://www.hyundai-forums.com/threads/33-point-inspection-necessary-every-3700miles-6000km.160214/
http://www.hyundai-forums.com/threads/fsm-hyundai-fluids-chemicals.175097/
Engine Threads:
http://www.hyundai-forums.com/threads/video-engine-air-filter-check-replace.245457/
http://www.hyundai-forums.com/threads/if-your-engine-went-bad-vote-here.222665/
http://www.hyundai-forums.com/threads/chatroom-engine-trouble-noise-problems-etc.213465/
http://www.hyundai-forums.com/threads/chatroom-2-0t-engine-issues.198153/
http://www.hyundai-forums.com/threads/engine-dead-22k-miles.185577/
http://www.hyundai-forums.com/threads/engine-break.202082/
http://www.hyundai-forums.com/threads/2-4-engine-vs-2-0t-engine.196273/
http://www.hyundai-forums.com/threads/chatroom-santa-fe-spark-plugs.197569/
Check Engine Light Codes: (common)
http://www.hyundai-forums.com/threads/check-engine-light-code-p2118-=-throttle-actuator-control-motor-current.327505/
http://www.hyundai-forums.com/threads/check-engine-light-code-p0303-=-cylinder-misfire.326681/
Transmission Threads:
http://www.hyundai-forums.com/threads/transmission-issues-2013-sfs-2-4-a.231449/
http://www.hyundai-forums.com/threads/2-0t-transmission-performance.166049/
http://www.hyundai-forums.com/threads/transmission-clunk.203930/
http://www.hyundai-forums.com/threads/awd-fwd.154990/
http://www.hyundai-forums.com/threads/gear-lever-problems.231137/
http://www.hyundai-forums.com/threads/transmission-shift-cold.222137/
http://www.hyundai-forums.com/threads/chatroom-transfer-case-fluid-change.332593/
DIY INSTALLS & REPAIRS: (do it yourself):
http://www.hyundai-forums.com/threads/diy-engine-oil-change.164238/
http://www.hyundai-forums.com/threads/diy-change-sf-dm-fogs-lights.163135/
http://www.hyundai-forums.com/threads/diy-2013-santa-fe-sport-parking-brake-shoe-replacement.520385/
http://www.hyundai-forums.com/threads/diy-cold-air-intake-bpv-bov.158517/
http://www.hyundai-forums.com/threads/diy-rear-differential-fluid-drain-video.246065/
DIY: HITCH INSTALLATION INSTRUCTIONS (pdf)
DIY: New Oil Pan Install (pdf)
http://www.hyundai-forums.com/threads/how-do-i-adjust-headlights.84167/
http://www.hyundai-forums.com/threads/removing-upper-dash-trim-center-storage.160336/
http://www.hyundai-forums.com/threads/radar-detector-mirror-mounted.166817/
http://www.hyundai-forums.com/threads/diy-front-brake-pad-check-clean-video.321505/
http://www.hyundai-forums.com/threads/diy-removing-front-bumper-cover.325657/
http://www.hyundai-forums.com/threads/chatroom-firewall-access-holes.326498/
http://www.hyundai-forums.com/threads/spare-tire-pressure-psi-have-you-checked-lately.163305/
http://www.hyundai-forums.com/threads/front-pillar-removal.177274/
http://www.hyundai-forums.com/threads/radio-removal.308402/
ENGINE MANAGEMENT (modules & apps):
http://www.hyundai-forums.com/threads/obd-modules-torque-kiwi-apps.161484/
LIGHTING (mods, installs, etc):
Headlight Beam Adjustment / Aiming (pdf)
http://www.hyundai-forums.com/threads/diy-hid-xenon-install.164308/
http://www.hyundai-forums.com/threads/chatroom-hid-xenon-headlight-conversion.157953/
http://www.hyundai-forums.com/threads/chatroom-drl-daytime-driving-running-lights.150539/
http://www.hyundai-forums.com/threads/led-foglight-bulb.155308/
http://www.hyundai-forums.com/threads/hyper-yellow-fog-lights.159686/
http://www.hyundai-forums.com/threads/rear-led-tailights-reflectors-license-plate-lights.146800/
http://www.hyundai-forums.com/threads/interior-led-lighting.157204/
EXTERIOR MODS:
http://www.hyundai-forums.com/threads/chatroom-plasti-dip-vinyl.163195/
http://www.hyundai-forums.com/threads/de-badge.162756/
http://www.hyundai-forums.com/threads/flying-eagle-badge-swap-mod.164322/
http://www.hyundai-forums.com/threads/rear-reflective-mod.164278/
CLEANING, POLISHING, WASHING (tips, advice, diy's, etc):
http://www.hyundai-forums.com/threads/cleaning-tip-bumper-honeycomb.161996/
http://www.hyundai-forums.com/threads/chatroom-exterior-compound-polish-wax.152812/
http://www.hyundai-forums.com/threads/leather-seat-care.158510/
http://www.hyundai-forums.com/threads/cleaning-dash-suggestions-please.154031/
http://www.hyundai-forums.com/threads/chatroom-hood-door-bumper-paint-protection-vinyl-3m-other.158232/
AUDIO UPGRADES / MODS:
http://www.hyundai-forums.com/threads/audio-upgrade.156428/
http://www.hyundai-forums.com/threads/dash-kit-mounting-kit.160066/
http://www.hyundai-forums.com/threads/internal-hard-drive-capacity.149208/
http://www.hyundai-forums.com/threads/dashboard-tablet-mount.164326/
NAVIGATION (in-dash):
http://www.hyundai-forums.com/threads/australia-mapcare-updates.159912/
http://www.hyundai-forums.com/threads/unavi-oem-inetegrated-navigation-2013-santa-fe.153180/
Suspension:
http://www.hyundai-forums.com/threads/2suspension-stiff-when-its-cold.32249/
OFF ROAD (mud, snow, etc):
http://www.hyundai-forums.com/threads/chatroom-off-road-mud-sand-woods-etc.154566/
http://www.hyundai-forums.com/threads/chatroom-winter-snow-driving.157542/
http://www.hyundai-forums.com/threads/magna-awd-system.156899/
http://www.hyundai-forums.com/threads/blizzard-2013-a.155405/
http://www.hyundai-forums.com/threads/awd-diagonal-spin-test.227553/
TOWING:
http://www.hyundai-forums.com/threads/chatroom-towing-hitch-receiver-trailers-etc.148437/
RIM & TIRES (OEM, all-season, winter, off-road, summer, etc)
http://www.hyundai-forums.com/threads/chatroom-winter-snow-tires.150465/
http://www.hyundai-forums.com/threads/chatroom-all-season-tires-oem-non.161183/
http://www.hyundai-forums.com/threads/tire-pressure-sensor-tpms.164305/
http://www.hyundai-forums.com/threads/new-aftermarket-rims.164317/
http://www.hyundai-forums.com/threads/wheel-offset-2-4-awd-sport.174321/
ACCESSORIES:
http://www.hyundai-forums.com/threads/side-window-deflectors-rain-guards.159594/
http://www.hyundai-forums.com/threads/accessories-galore.163252/
http://www.hyundai-forums.com/threads/trunk-organizer.164311/
http://www.hyundai-forums.com/threads/chrome-accent-trim.164310/
http://www.hyundai-forums.com/threads/tint-new-2013-santa.162582/
http://www.hyundai-forums.com/threads/front-rear-push-bull-cow-bar.158369/
http://www.hyundai-forums.com/threads/all-weather-rubber-floor-mats.150422/
http://www.hyundai-forums.com/threads/roof-rail-crossbars-both-pano-metal-roofs.148979/
http://www.hyundai-forums.com/threads/2013-santa-fe-running-boards-side-steps.151023/
http://www.hyundai-forums.com/threads/2013-santa-fe-hyundai-genuine-accessories-chart.175113/
http://www.hyundai-forums.com/threads/chatroom-dash-cams-diy-install.300978/
BLUE LINK (issues, stories, complaints, recommendations, etc):
http://www.hyundai-forums.com/threads/had-some-fun-bluelink-app.163391/
HYUNDAI CUSTOMER CARE RELATED (complaints, issues, resolutions, etc):
http://www.hyundai-forums.com/threads/poor-customer-service.162729/
http://www.hyundai-forums.com/threads/hyundai-comprehensive-reimbursement-program-mpg-error.150848/
POPULAR TOPICS:
INFO:
Engine Threads:
EXTERIOR MODS:
Suspension:
TOWING:
ACCESSORIES:
Looks like all are working except -163456 / Engine Threads, and
Looks like all are working except -163456 / Engine Threads/
