I own a 2017 Santa Fe sports AWD and in here recently since a month or more the audio system decides to start itself automatically and won't shut off whatever you do start stop car multiple times, take a short trip and on off and suddenly it works normal again
Including lighting on front panel surrounding audio system and sometimes the changing pods as well
Took to dealer they mentioned fuse box might be culprit and replaced it though it seems problem still persists
My biggest worry is it might drain the battery and we might have to call a tow truck
Does anyone else have similar issue or know resolution
Land vehicle Car Vehicle Electronics Multimedia
Electronics Car Vehicle Audio equipment Technology
Another - possibly undocumented - 'feature' forced on consumers that assumes they want the radio turned on every time they start the ignition. 🤦‍♂️
Gosh I can't WAIT to get back to the '50s or '60s....!
Not kidding - I'm on a special list
2013 Hyundai Santa Fe Sport
Yes this seems like an issue with the smart junction box or the bcm. Need to have someone scan those modules for codes
Quick question....any aftermarket electronics on the car (amp/subs, trailer light kit, etc)? These can wreak havoc on a canbus vehicle when they begin to fail.
Sent from my SM-G965U1 using Tapatalk
to fail.
"bcm" spells H.O.E. = He77 on Earth when it involves Body Control!
In my present 2010 Honda Accord, if I park, turn off the engine, and don't remove the key within 30 seconds of turning engine off, the doors will lock, and when i remove key from ignition, the alarm goes off! Pressing the unlock on the armrest will not unlock, and I have to manually unlock the driver door to open it and get out.
Meanwhile, NO buttons on the keyhead(My Honda key is integrated fob), can cease the alarm until all are pressed, and neighbors are awakened, or parking lot customers startled at the supermarket, etc.
Another reason the mid-20th century awaits me.... And it will be soon....
