Hi guys,
Drove my Getz (2004) home as usual, parked for 2 minutes, come back and now the car won't start. The car won't even turn over/make any noise at all (besides the fuel pump i'm assuming).
I've owned this car for 5 days, this morning it happened once but I assumed i didn't have my foot hard enough on the clutch - tried again and it started as normal.
Just because it's quick and easy, when it wont crank over the first thing I'd do is a bypass test on the START relay on the engine bay fusebox. If it cranks when the relay is bypassed you at least know the starter motor, battery and the connections out in the engine bay are all good.
Make sure the gearbox is in neutral
Switch the ignition on
Remove the START relay from the engine bay fusebox
Use a short link wire to bridge the two terminals of the relay socket on the fusebox as shown below :
