Ladies and Gentlemen
I have a problem with my 2004 Getz 1.3 steering system, it makes so bad sound sound when turning the vehicle, I refilled the pawer steering oil and went quite for about 3 days and started again and if I thoroughly check it looks dirty. So now I have considered changing it but don't know how to do so. If I turn the steering wheel while the vehicle is not idleing the oil resevoir overflws and don't know whether this is normal or not , Please help and thank you in advance.
Linda.:)
power steering fluid
Hi if you have had to top up the power steering fluid the chances are that you have a leak. Put a bit of cardboard under the car at the engine area and leave overnight and this will give you an idea where the leak is coming from. The fluid will be dirty in appearance because the fluid reacts with the rubber gaskets which makes it look black. Laurence
