Hi, my getz gl 1.6 2005, at startup, the engine starts accelerated, between 2.5 and 3 thousand RPMs, with fluctuations up and down those numbers.
I can't solve that problem to drive the car to a mechanich and can't bring one here becouse I live far from the nearest city.
Is a fuse problem? CPU maybe? Has anybody happen to know how to solve this issue?
thanks in advance.
Hola, mi hyundai getz gl 1.6, al arrancarlo, el motor parte acelerado marcando entre 2.5 a 3 mil revoluciones, fluctuando entre esas cifras. No se como solucionarlo y por este mismo problema no podemos llevarlo a servicio técnico.
es algún problema de fusibles? el CPU a bordo?
that part you mention is like the system that blows air into the engine, right? (i'm an ignorant on cars, any car... never get the hang of it)
Is like the air filter or blower for the accelerator, i guess. so, if I take it appart and clean it, it should work till can get it to the nearest mechanic.
if i got it right, if it blows i let you know LOL. thanks!
