I'm sure this must be somewhere on this forum but I can't find it using keywords?! Has someone got the service schedule for this car please. I was a bit shocked to be told the oil should be changed every 5000km!!! Thanks in advance.
MODERATOR
QUOTE (caeygee @ Sep 28 2010, 02:31 PM) index.php?act=findpost&pid=359399
Here is some useful information for your Getz
Robert B.
[attachment=20457:GI.pdf]
As for oil change intervals, it all depends on your driving conditions, oil quality used. Every 5000 kms sounds about right if using regular mineral (non sinthethic) oil and under somewhat dusty and humid conditions.
Replace oil filter every time.
Check brake pads every 10000 kms
Replace timing belt every 70000 kms
Replace brake fluid every two years or 40000 kms
Replace transmission fluid every two years or 40000 kms.
Replace spark plugs once a year.
Check air filter once a month and replace if seems clogged or too dusty (replacement usually every 10000 kms under normal to dusty conditions).
As for other stuff, just check every once in a while and replace or adjust accordingly.
