1 - 11 of 11 Posts
Hi there,
I've had this issue with my Getz for a few months now and I've taken it to 5 different mechanics and no one seems to know what the issue is. Each time I try to turn on the car, it's as if the battery is completely dead, so I have to jump start it. I've changed the battery 3 times already and nothing seems to work. It's as if there's something killing the batter each time. Any advice?
Thanks in advance
Hi there,
Thanks in advance
Have the mechanics checked over the alternator? You say it seems as if it kills the battery, what if the battery is being charged by the alternator? Just a guess ?
Sent from my ONEPLUS A3000 using Tapatalk
2007 Honda CRV
If there is an issue starting car after it has been sitting quite a while
Then there is a possibility of a parasitic drain
It can lower the battery capacity to hold a charge
And require jump starting each time
Discussion Starter · #10 ·
Sorry, I don't know anything about cars, so wasn't sure how much info was too much or too little. Ok all the things checked/replaced:
- Alternator replaced
- Parasitic Drain checked
- Spark plugs replaced
- 3 new batteries replaced (all brand new, all in the same month)
- immobilizer checked
- timing belts changed
- serpentine belts changed
it's basically a brand new car under the hood!
Is that enough info?
2007 Honda CRV
Only thing better would be to know how those tests were done.
I would now begin by cleaning battery terminals and battery grounding point at the chassis.
Follow the battery negative cable to the body of car.
Clean the contacts.
Swap the starter relay with another of the relays in the fuse box
Clean the ignition wire that goes from the ignition switch to the starter solenoid
Sometimes the corrosion on the contact is enough to keep it from starting.
The only other thing is to replace the ignition switch (not the ignition lock cylinder)
1 - 11 of 11 Posts
