Does anyone have any opinions about driving with the ESC off and driving in manual mode with the tranny?
My question is this: With ESC off and in manual mode have you found that the shift points are better if you let the tranny shift itself (even in manual mode) or if you manually control shift points.
Thanks
QUOTE (booga_1979 @ Oct 2 2010, 09:46 PM) index.php?act=findpost&pid=360501
Thanks
I always let the trans shift itself on the manual mode....seems to work better for me.
I also notice the Transmission shifts better with ESC off, I use esc off and use auto mode seems to work for me just fine.
when roads are slippery I start off in d2 manual mode, drive by wire is very touchy so using higher gear gives better control.
