1 - 10 of 10 Posts
hi i drive a 2001 trajet manual gearbox and I've started having problems selecting 3rd 4th and sometimes 5th. 1st and 2nd are fine. sometimes it's ok and goes straight into 3rd but then you can't get 4th and other times you can't get 3rd but straight into 4th and 5 seems further across but i have found when i can't get 3rd if i reach around 3500 rpm in 2nd it'll let me in 3rd? any ideas
Sounds a bit like the Syncromesh is past its sell by date. Normally it would be 1st and sometimes second playing up. Is your clutch disengaging properly? What's the mileage? Try using "double declutch" if you know how to do it. If that improves the gear change then your syncro rings are gone. Can't think of anything else at the moment.
I suspect your gearbox is gone. Have it checked by a trustworthy gearbox specialist without any commitment. If the car is in good nick it might be worth it to get a second hand box from e-bay.
Have you checked the linkage between gear lever and box? It might be that the linkage is faulty/worn. Don't know if there are any cables or con rods on the Trajet but it might be worth it to check that area as well.
how easy t is to remove the gearbox from 1 of these as never done 1 on a trajet .....just dont look like there's enough room without taking engine out
Hi all have a 2005 trajet 2lt diesel with the 1st and 2nd gear problem looks like it a problem with this model does anyone know if there are any recalls or a mod that can fix the problem ?:mad:
Discussion Starter · #9 ·
well the cars gone into the dealership this morning so i'll let you all know what they say later....costing £60.00 for them to take a look but it might be worth it if they come back and say it's gear linkage not gearbox
Discussion Starter · #10 ·
ok the dealership said it's deffo the gearbox and quoted me 2500.00 to fix it.....errrrrm no chance so it's time to let it go to scrap......been a domn good car aswell
1 - 10 of 10 Posts
