· Registered
I have a 2015 Elantra and my boyfriend went to fill up my tank (my gas light was on at this point) and it stopped filling after about 2 gallons and started to overflow when he tried to continue pumping. I started my car back up and it said I only had a little less than half a tank full. What's the problem? I've already had other problems with this car, it seems never ending ??
· Registered
Hard to refuel
(Overflow during refueling)
1) Inspect the fuel filler hose/pipe
· Pinched, kinked or blocked?
· Filler hose is torn
2) Inspect the fuel tank vapor vent hose between the EVAP. canister and air
filter
3) Check the EVAP. canister
· Registered
Hard to refuel
filter
Is this general information or was this lifted from a Hyundai manual for the Elantra?
Just to add, it could be electrical in nature. Perhaps the sending unit is sending false/bad information to the gauge or the gauge itself you have a problem.
· Registered
Service Manual
You are right it could be the Fuel Level Sensor located in the gas tank, the sending unit, the gauge, etc.. I figured start of with the easy and work toward the harder.
One way to troubleshoot is to put a can of gas in the back and if you can drive more than 60~70 miles after the "gas light" comes on, you know it is something electrical.
