Hi
Have a 2008 UK spec santa fe cdx 7.
Cannot find any fuse in the handbook for the cruise control.
CC - it appears to do nothing - and brake lights work fine as i know it works via the brake switch.
1 where do I locate the cruise control fuse - none are listed on the cover for fuses either
2 any great suggestions if the fuse is fine ?
I dont even get a CC dash light - and instruments all light up fine.......
ideas please ! :(
Cruise control is like all throttle functions on this vehicle - 'drive by wire' - so there is no separate fuse as there used to be in the days when there was a mechanical drive of some sort to a throttle cable. Either the signal requesting CC isn't making it to the ECU from the steering wheel switch, or the ECU is refusing to engage cruise for is own reason. Will be necessary to determine just what that is.
Need to run now. More later.
