My 2008 Azera manual describes a fuel tank air filter which should be replaced at 30,000 miles. I have no clue where this is and how to replace it. Any suggestions?
Also, as my Azera is at 32,000; I thought i'd go ahead and drain and fill the transmission and do it myself after buying fluid from Hyundai dealer. Is simply draining the 5-6 qts. that comes out of the drain plug sufficient or is that worthless unless you disconnect the tranny cooler line and run engine till all fluid is out and refill with same qty.?
thanks.
thanks.
