1 - 1 of 1 Posts
Ok...so here's the thing...there is a white wire coming from the ECM that is supposed to supply a ground to the control side of the fuel pump relay. It was intermittently working but now has failed completely...now before I get a new ECM and pay for it to be flashed...is there any other possible cause for the ECM to not make the ground? I already tested the Crank sensor and it is fine...I have temporarily bypassed the relay to make the car run...but if I leave it like that it will eventually burn out the pump from constantly running...any thoughts would be appreciated.
1 - 1 of 1 Posts
