1 - 11 of 11 Posts
Hi guys, I'm back with a question. The fuel line termination inside the engine bay started to leak, rubber is falling apart. How hard is to replace it, how long is that segment - looks like it goes into the firewall?
Discussion Starter · #2 · (Edited)
Looks like is the 31320 part. Is that easy to separate from the next line (31310)?
That piece of line is a service part. Replaced 1 earlier this year.. we have done a few in the past
Be aware that the part is kinda $$... worst part of job is trying to support the tube off bulkhead with wrench and getting other side of joint loose to undo the connection..
Thanks. If that connection is as 'stuck' as my fuel filter was, I can see being complicated.
I need to see how expensive it is at the local dealer, I don't think a junk yard part would be aged better. Unless... newer models/years are identical?
Do you know what is the last year that used the same part like my 2000 V6?
Discussion Starter · #6 · (Edited)
Would you look in the system what exact number I need (2000 model - mfg date says 1999, V6, 2.5L)? Seems like V6 2.5L is 31321F, not the 31320?
I did found several variations:
31321-38100
31321-39160
31321-38150
31321-38100
31321-39160
31321-38150
Need VIN.. easiest to visit local dealer and let fella load VIN, then pick the hose as called out by HYundai.
Discussion Starter · #8 ·
Thank you.
If somebody looks for the same thing, for 2.5L V6, it was hose #31321-38150, it costs around $100, and can be found also at Kia (same part number, $85).
Discussion Starter · #9 · (Edited)
Heeelp again...
How is the tread on the fuel line connection? 'Normal' direction? It won't budge. I have two wrenches (17 and 14mm) pushing, pulling one against each other... nothing. Used PB Blaster... Are those NPTF Dryseal type?
HEHEHEE... normal oversize brake line setup.. They is STUPID TIGHT !!
Best to use wrench on the larger hose end, and a 14mm crowfoot line socket of 14mm.. have 2 people to do this, PIA to do alone.. 1 person hold large wrench, other person turn the line nut while supporting the line so it dont twist away from you and kink/buckle the steel line.. BE CAREFULL..
When you put it back together,, snug it up moderately,, not Superman super torque.
Discussion Starter · #11 ·
They didn't hear of quick disconnects? Gosh...
1 - 11 of 11 Posts
