1 - 8 of 8 Posts
would a clogged filter cause missing at idle and when you start to move off from a standstill and yet it runs fine at speed. it starts fine but idles bad and misses alot at idle. tune up done since this started. all new parts still have problem. any advice helpful. thanks for looking
Take a can of CARB and spritz it along the seam where the intake manifold meets cylinder head... likely find vacum leak at #2 or #3... quite common occurence on old baked 2.0L
QUOTE (jsinton @ May 27 2010, 06:27 PM) index.php?act=findpost&pid=327086
Could be a clogged fuel filter, but not the usual MO. If you're not sure when it was changed last, then certainly I'd change it.
Clogged fuel filter will not make for random mis-fire.. might find 0171 lean code because of insufficient fuel...
1 - 8 of 8 Posts
