Does a 2005 Hyundai Tucson have a fuel cut off switch? Car will not start. I have changed the fuel pump, checked fuses and relay switch.
I'm pretty sure the Tucson does not have a fuel cut off switch (inertia switch).
I love it when folk ask for help with an engine problem but don't even think to mention what engine it is we're working with??
Did you use a voltmeter to check the fuses? If not I'd suggest you switch the ignition on then probe the test points on top of each fuse with a voltmeter to check that none are blown, and to check that the ones that are supposed to have power actually do. Specifically the INJ & SNSR (Injector & Sensor) fuses on the engine bay fusebox.
