Front Wheel Hub Nut
2049 Views 2 Replies 3 Participants Last post by  Montego
how do i lock the front wheel to remove the hub nut......am replacing the tone ring,any other advice on that aswell(05 CRTD.ireland)
Re-install the brake rotor and stick a long screwdriver through the vent holes and position the screwdriver to block the rotation, or if you use a good impact gun holding it by hand works.
next time you have to do the job make sure you loosen the hub nut BEFORE you jack the vehicle up
